![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
you don't need to have drums resurfaced. you can just have them sanded down on its inside surface, though not extremely necessary. using sandpaper will do. besides if you adjusted them and they don't have the bite as they used to, they're either:
1) good for track use because they need to heat up a little (designed to have less brake fade in continuous use), or 2) very bad shoes. |
#2 | |
![]() Drives: 06 Yaris YR Join Date: Aug 2014
| handbrake warning alarm?? | caineroad | DIY / Maintenance / Service | 20 | 05-20-2013 08:36 PM |
| Help with Loose Handbrake | Roth5150 | DIY / Maintenance / Service | 3 | 09-14-2011 10:56 AM |
| Handbrake Loose | Roth5150 | General Yaris / Vitz Discussion | 1 | 09-12-2011 09:03 PM |
| Had my brakes done....now handbrake is harder to pull. | captainm27 | General Yaris / Vitz Discussion | 7 | 05-10-2010 07:00 PM |
| Auto trans : Drive to Park + Handbrake : was not in park... | Maxh91 | General Yaris / Vitz Discussion | 7 | 06-11-2009 06:37 PM |
