Old 09-18-2014, 09:56 AM   #4
jcboy
Drives: Sedan 07
you don't need to have drums resurfaced. you can just have them sanded down on its inside surface, though not extremely necessary. using sandpaper will do. besides if you adjusted them and they don't have the bite as they used to, they're either:
1) good for track use because they need to heat up a little (designed to have less brake fade in continuous use), or
2) very bad shoes.
handbrake warning alarm?? caineroad DIY / Maintenance / Service 20 05-20-2013 08:36 PM
Help with Loose Handbrake Roth5150 DIY / Maintenance / Service 3 09-14-2011 10:56 AM
Handbrake Loose Roth5150 General Yaris / Vitz Discussion 1 09-12-2011 09:03 PM
Had my brakes done....now handbrake is harder to pull. captainm27 General Yaris / Vitz Discussion 7 05-10-2010 07:00 PM
Auto trans : Drive to Park + Handbrake : was not in park... Maxh91 General Yaris / Vitz Discussion 7 06-11-2009 06:37 PM
