Old 10-05-2014, 10:53 PM   #1
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
question on brake pin grease
I just inspected brakes on my kid's Yaris and the outer ones had a bit more wear compared to inner ones on both sides. Only about 50% pad wear at 70,000 miles. They were OEM toyota pads (made by Akebano), so I assumed factory. There was some semisolid yellow-gray pin grease, a bit harder than it should be, and the pins a bit stiff, so I re-greased them with the proper pink toyota rubber grease as per the factory manual. I did something right, because the kid came back home safely afterwards.
Now, the question is: is the yellow pin grease factory or the previous owner stuck some bearing grease there?
One more thing, I planned on bleeding the brakes and replacing the brake fluid, but aborted due to brake reservoir hiding way back there under wipers. Do you have to remove wipers to get access there?
jack black is offline   Reply With Quote
Old 10-05-2014, 11:46 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
There is a plastic piece that u can remove to get to the reservoir right above just have a close look and ull see.
As for slider pins I use synthetic grease ( less is more) and spray it with synthetic lube I find it works best ,sliders move nice and free also make sure rubber boots are in good shape. As for where the pads sit use same grease as on pins ..don't need much. Basically all should move free and yes I find that the piston side pad wears out sooner to get more out of ur pads just flip them around .
sent from my S4 on Mars
Old 10-06-2014, 01:09 PM   #3
jack black
jack black's Avatar
Thanks.
My pattern was the opposite.
I found my answer here:
Posted on ToyotaNation Re: sienna brakes. My pins looked similar, but with a bit more of that yellowish grease. Hence it was likely factory grease alright.
Old 10-06-2014, 07:37 AM   #4
woops
Drives: Jeep Cherokee XJ 1996
If i run out of the Toyota grease i clean the pins and use nlgi 0 or 1 dielectric silicone grease.
I use this grease on most cars except the ones that have pins that aren't covered. . For those I've had good experience with PBC grease. . Learnt this from Nissan
woops is offline   Reply With Quote
Old 10-22-2014, 10:39 AM   #5
tmontague
tmontague's Avatar
Make your life easier and go to Canadian Tire or equivalent and buy a syringe for mixing oil/fuel mix. It comes with a short vinyl hose (or you can buy longer) and you can just stick the hose into reservoir to pull out old fluid and put new in. I did this with mine the other day when bleeding my clutch and it worked great and saved me the hassle of having to remove the plastic cover
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
