Old 10-05-2014, 11:46 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
There is a plastic piece that u can remove to get to the reservoir right above just have a close look and ull see.
As for slider pins I use synthetic grease ( less is more) and spray it with synthetic lube I find it works best ,sliders move nice and free also make sure rubber boots are in good shape. As for where the pads sit use same grease as on pins ..don't need much. Basically all should move free and yes I find that the piston side pad wears out sooner to get more out of ur pads just flip them around .
sent from my S4 on Mars
Old 10-06-2014, 01:09 PM   #2
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Thanks.
My pattern was the opposite.
I found my answer here:
Posted on ToyotaNation Re: sienna brakes. My pins looked similar, but with a bit more of that yellowish grease. Hence it was likely factory grease alright.
jack black is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
