Old 11-21-2014, 01:34 PM   #1
TheBeerglar
Drives: 06 Yaris RS 4Dr Hatchback
To clarify I I do not have a key fob I only own a key.I would like to get a new one in order to have keyless entry.
The reason I believe that The 2007 is different from my 2006 is that the locksmith I went to said that for a 2007 I would need a programmed key running at about $80, however, with my year I simply need a standard key for $5.
I asked the dealership to check my VIN and see if OEM keyless was originally available with my car and they confirmed that it did.
TheBeerglar is offline   Reply With Quote
Old 11-21-2014, 02:21 PM   #2
With the key, if your ignition switch is all metal then you have non-transponder keys (which require no programming). If only the small round part that rotates with the key is metal and the outer part is black plastic, then you have transponder keys, which do require programming.
With the key fob, the car was available with remote entry that year, but the question is if yours was actually built with it (and the prior owner just didn't pass on the remote). If it was not, then quite a bit more than the fob is required to add it.
Old 11-25-2014, 10:51 AM   #3
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
My keys have no buttons whatsoever but my ignition is plastic
Sent from my HTC Explorer A310e or my awesome Xperia Z1 C6903 using Tapatalk.
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 11-25-2014, 12:38 PM   #4
So, you don't have keyless entry (buttons on the key would be for locking and unlocking the doors), but you do have the engine immobilizer (transponder keys).
Tags
fob, key remote, keyless entry, programming, yaris
Yaris 2007 remote entry doesn't open (it only closes) nicorac In Car Entertainment + Electronics (audio / video / alarm) 7 09-08-2011 12:02 PM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 03:11 PM
