Old 11-22-2014, 07:00 PM   #18
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I have so many questions on this swap.
What mounts did you fabricate? The 2zz mounts or the 2nz mounts?
You said you changed from manual to auto trans. What shift linkage did you use and how are they rounted?
Wire harness... Did you modify the Yaris engine harness, or use entire celica engine and cabin harness. what and where were you splicing (i.e. at the ecu or the engine bay)
also, to support the CAN system for A/C controls, are you still using the Yaris ecu?
now, you say its a Vitz 1.0.. Did that have the electric power steering or the pump? also, was that drive by wire throttle cable or drive by cable on the original 2nz motor? If I had to assume, it was drive by cable and power steering pump. But just wanted to be sure
-Derrick-
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
