#18 |
I have so many questions on this swap.
What mounts did you fabricate? The 2zz mounts or the 2nz mounts? You said you changed from manual to auto trans. What shift linkage did you use and how are they rounted? Wire harness... Did you modify the Yaris engine harness, or use entire celica engine and cabin harness. what and where were you splicing (i.e. at the ecu or the engine bay) also, to support the CAN system for A/C controls, are you still using the Yaris ecu? now, you say its a Vitz 1.0.. Did that have the electric power steering or the pump? also, was that drive by wire throttle cable or drive by cable on the original 2nz motor? If I had to assume, it was drive by cable and power steering pump. But just wanted to be sure
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
