Old 12-04-2014, 10:04 PM   #1
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
I stumbled across this thread and now I'm thinking I better do this! I got the letter about a year ago and forgot all about it.
I think I'll try to get them out myself. I'm wondering why no one has thought to try and find better bolts.. something that has more resistance to corrosion.. like stainless steel maybe? What do you all think? Does stainless torque well? Will it hold the 118 ft/lbs?
Any input is appreciated.
CueBall is offline   Reply With Quote
Old 12-05-2014, 06:24 AM   #2
Stainless is too brittle for this application.
Old 12-09-2014, 05:16 AM   #3
dkwilfert
Drives: 2008 Yaris 2-Door (White)
SS Too Brittle?
Just curious, what was the source of the information that stainless is too brittle for this application? That seems to imply quite a bit of motion/flex at this joint.
dkwilfert is offline   Reply With Quote
Old 12-09-2014, 06:03 AM   #4
The bolt is mounted in a metal tube that is then suspended in dense rubber so that the control arm can move, so there is definitely flex at that joint. The right blend of stainless would be fine, but off the shelf bolts would be more brittle of a stainless blend then would be appropriate.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
