Old 02-10-2015, 02:48 PM   #1
The Limo 2
Under normal service, Toyota USA says to check your transmission fluid at 100,000 miles and then every 50,000 miles after that and not to change it unless there is something wrong with the fluid. They treat it as a lifetime fluid.
As you can see in my post #3 above this is different than Toyota Canada.
Roy
The Limo 2 is offline   Reply With Quote
Old 02-20-2015, 07:53 AM   #2
lenzomaru
lenzomaru's Avatar
Drives: 07' Yaris S & 89' Mazda 323 LX
Roy
My manual says that as well..check at 100,000 and inspect every 50,000..but how will you know something is wrong with it?
"Cooler than the other side of the pillow"
lenzomaru is offline   Reply With Quote
Is it ok to change Engine Oil after longer durations??? CT Scott please advice too tyrone_yaris DIY / Maintenance / Service 11 04-04-2014 11:52 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
Oil Change Question... jayeh DIY / Maintenance / Service 4 03-05-2012 11:15 PM
transmission fluid that indicate must change susucosp DIY / Maintenance / Service 3 12-10-2011 11:51 PM
