Old 09-01-2016, 07:57 AM   #1
neofitos
Drives: Yaris 1.3 2012
thanks a lot. i will buy one in a week . As soon i install it i'll be back to post if it worked or not!
Thanks a lot again!
neofitos is offline   Reply With Quote
Old 09-08-2016, 05:42 PM   #2
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
Originally Posted by neofitos View Post
Hello everybody,
I am from Greece!
I have a 2012 Mk3 Yaris, made in France.
I bought an ebay fog light kit(lamps wiring and switch), installed the lamps, the wiring already exists.
I cannot do the connection inside the cabin for the switch.
I have read all the threads for ebay fog lights. I put a fuse for front fog lights under the dash panel .
Connecting pin 3 to pin 4 in the stalk light switch will not light my front fog lights.
Everybody says that relay already exists(i cannot see it).What am i doing wrong??
My Yaris has alarm installed by Toyota, i dont know if this helps somewhere.Furthermore my genuine toyota light switch installed on the car has only a spring powered switch for the rear fog lights . There is no position in the geuine switch for the front fogs.
Shall i buy a new toyota switch with two positions??
Every opinion is appreciated! I have been searching everywhere, Toyota here in greece say that they do not help me because it is aftermarket and if sth goes wrong i will blame them.(I cannot understand that since the wiring already exists , there is nothing aftermarket except the plastic cover from the lamps)
Have you inserted grey relay? Refer to photos on 24 of this post.
If you have used the existing wiring, inserted the grey relay, your fogs are working (you can verified that by connecting them straight to the battery) and toyota stalk has the front fogs option your front fogs should come up along with your lights
karloslatynos is offline   Reply With Quote
Old 09-08-2016, 06:08 PM   #3
neofitos
where do i get the grey relay? mine is a LHD and it is really hard to find relay.it is under the steering wheel(not the glove box)
In a greek yaris forum one guy said that in his french made yaris the relay was already in place, he just pluged the lights and used a switch
Old 09-08-2016, 06:15 PM   #4
karloslatynos
The grey relay should be there. I think its R/B No.5
Old 09-08-2016, 06:25 PM   #5
neofitos
i will check again tomorrow. The first time was hard to get in there!
Old 09-09-2016, 03:39 PM   #6
neofitos
FINALLY!
took the gray relay from the fuse box in the engine area(i dont know if it was needed there, everything still works in the car).Installing the relay in LHD models is not that easy, you will have to find the spot next to one blue relay(many wiring and other stuff in there)
Front fog lights work now!!
So, in brief, if you want to install ebay fog lights with yari's existing wiring , you have to:
1) plug the lights in the front bumper and connect them to the existing wiring
2) buy a genuine light stalk/switch that has 2 positions(one for front fogs and one for rear fog)
3) make sure that the fuse for the front fogs is in place(in the fuse box that is in the cabin)
4)buy a grey relay ,if needed. (Toyota 90080-87021) (you can find one in the fuse box in the engine area,i am not 100% sure if you are supposed to remove it )
5)install the relay in the cabin ,if needed. in LHD models you install it on the left side of the steering wheel next to a blue one.(quite hard to find , try more)
6) front fogs now work , the light on the dashboard for the front fogs also lights!
A big thanks to Karlos for his help!
Old 08-08-2016, 08:26 AM   #7
neofitos
thanks a lot for your quick answer karlos!!
this is the one that i bought.there was no manual. i want to use the existing wiring
http://www.ebay.com/itm/380995092067...%3AMEBIDX%3AIT
where should i connect the new switch? what kind of switch should i buy?
do you have any link ?
Old 10-27-2017, 04:39 AM   #8
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
Hi I have 2013 toyota yaris multidrive. it is prewired for fog lamp. so i fixed the fog lamp and noticed there is no switch for the same. so i take my car into auto electric workshop and they couldnt able to locate the relay. Could someone please help me to solve this issue.
What are the items I have to purchase ? and how to fix.
http://www.yarisworld.com/forums/showthread.php?t=59173
HDTechVideo is offline   Reply With Quote
Old 11-07-2017, 08:05 AM   #9
HDTechVideo
Hi could you please guide me how to remove the steering wheel mk3 yaris. Im trying fix the fog lamp with bew indecator stalk and relay. I can only be able to remove the back cover of the steering wheel.
I cant able to locate any screw for airbag removal.
Sent from my SM-G935F using Tapatalk
Old 11-07-2017, 06:07 PM   #10
karloslatynos
Removing the steering wheel airbag is quite awkward.
Take a look at that thread
http://www.yarisworld.com/forums/sho...t=37205&page=2
You will find there the informations and pictures how to do it.
Old 11-08-2017, 04:59 AM   #11
HDTechVideo
Thank you.
Old 11-10-2017, 02:34 AM   #12
HDTechVideo
Thank you Karlos
https://youtu.be/H8r_oUV_plI
Old 11-11-2017, 09:02 AM   #13
HDTechVideo
Hi
Everything installed and it worked fine for few minutes. then even the dashboard light went off. Fog light is not coming on. Any help is appreciated.
Thanks
Edit: Solved
Old 11-11-2017, 05:03 PM   #14
HDTechVideo
https://youtu.be/MugSOg2i5uU
Old 11-12-2017, 03:03 PM   #15
HDTechVideo
After installing fog light the fuse is always blowing. Will last only for few minutes. Any help. Thanks.
Yaris rear fog lights installation rtayyebi Cosmetic Modifications (Exterior/Interior) 1 11-14-2014 05:21 AM
