Old 09-08-2016, 05:42 PM   #23
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
Originally Posted by neofitos View Post
Hello everybody,
I am from Greece!
I have a 2012 Mk3 Yaris, made in France.
I bought an ebay fog light kit(lamps wiring and switch), installed the lamps, the wiring already exists.
I cannot do the connection inside the cabin for the switch.
I have read all the threads for ebay fog lights. I put a fuse for front fog lights under the dash panel .
Connecting pin 3 to pin 4 in the stalk light switch will not light my front fog lights.
Everybody says that relay already exists(i cannot see it).What am i doing wrong??
My Yaris has alarm installed by Toyota, i dont know if this helps somewhere.Furthermore my genuine toyota light switch installed on the car has only a spring powered switch for the rear fog lights . There is no position in the geuine switch for the front fogs.
Shall i buy a new toyota switch with two positions??
Every opinion is appreciated! I have been searching everywhere, Toyota here in greece say that they do not help me because it is aftermarket and if sth goes wrong i will blame them.(I cannot understand that since the wiring already exists , there is nothing aftermarket except the plastic cover from the lamps)
Have you inserted grey relay? Refer to photos on 24 of this post.
If you have used the existing wiring, inserted the grey relay, your fogs are working (you can verified that by connecting them straight to the battery) and toyota stalk has the front fogs option your front fogs should come up along with your lights
karloslatynos is offline   Reply With Quote
Yaris rear fog lights installation rtayyebi Cosmetic Modifications (Exterior/Interior) 1 11-14-2014 05:21 AM
