![]() ![]() ![]() Drives: 2007 Yaris HB 5spd Join Date: Jan 2015
accidentally hit the amt pin with ground
Was trying to aim headlights and accidently hit amt pin in fuse box inside engine compartment. Shut car off, headlights interior lights etc dont work now. And car wont start. Help me someone please?!
I am not sure what you mean by "amt pin", but you likely popped one of the large fusible links on the positive battery terminal.
I checked them and still intact. I have no hazards,turn signals interior lights gage clusters and wont start.
Check 30a power fuse.good. checked all mini's under steering column.good checked all fuses in engine compartment.good.
Have no radio either.
Or horn.
For the things that are out, it is almost definitely the 60A MAIN fuse on the positive battery terminal.
Temporary fix is tough. You could pop the clear cover over the link and solder it back together as a very temporary fix.
Your the man Scott. I over looked the fuseable link. Blown.
So I got the new fuseable link today. Put it in started the car. Got no blower fan airbag light on. Checked battery voltage while running. Volts dropping and alternator isn't kicking in. Checked 7.5 alt-s fuse. Fuse good. Checked 40 htr block fuse. Looks good. The amt slot is open with one pin in it. That the one I accidentally hit with ground when I was trying to aim my new headlights. Did I fry alternator? Seems to be the issue but want to make sure.
#12 | |
Thats the one beside the 60A main right? That one was intact. Took alternator out and having it tested today to see if I fried her. Is the voltage regulator integrated in alternator itself or seperate from it?
Ive got power down to alternator via cable. 120 alt fusable link not popped. Alternator just not kicking on. Rechecked all fuses. None blown.
Alternator tested good.
Ok. So I put alternator back in. Checked the voltage with out blower fan running and it charges. As soon as I turn knob to kick on blower fan voltage dropa which is normal. But fan doesn't work and alternator isn't kicking in to compensate for draw. Both fuses and fusable link good. All other accessories work normal. Just no blower motor and draw.
How far does the voltage drop with the fan on?
Not too far. 12.5 V range initially the over about 10 mins at idle voltage drops down to where it kills car. Blower doesn't blow air when switched on. Another thing I noticed is the battery light flickers a couple times upon start up the shuts off. Airbag light comes on at times upon start up and usually stays on when it does.
| DIY - Exterior lights on when doors are remotely unlocked | CTScott | DIY / Maintenance / Service | 21 | 07-31-2025 06:30 PM |
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| Wires Inside the Yaris & What They Do | The Architect | DIY / Maintenance / Service | 149 | 10-18-2022 03:32 AM |
| Auxiliary Input Help | Oned | In Car Entertainment + Electronics (audio / video / alarm) | 88 | 02-27-2016 01:32 AM |
| Viper Alarm Install | gwasabi | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 08-11-2010 02:57 PM |
