Old 03-13-2015, 11:23 PM   #1
Innovative 1
Drives: 2007 Yaris HB 5spd
Thats the one I accidentally hit with ground.
Innovative 1 is offline   Reply With Quote
Old 03-13-2015, 11:40 PM   #2
Right - That's what popped the original fusible link that was blown.
I would triple check and just in case replace the ALT-S 7.5A fuse and the 7.5A MET fuse in the under-dash fuse panel.
After checking those, measure the voltage on the small pink wire connected to the alternator. If you see 0 volts on that wire, then you definitely damaged the internals of the alternator.
DIY - Exterior lights on when doors are remotely unlocked CTScott DIY / Maintenance / Service 21 07-31-2025 06:30 PM
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
Auxiliary Input Help Oned In Car Entertainment + Electronics (audio / video / alarm) 88 02-27-2016 01:32 AM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
