Old 03-25-2015, 11:03 PM   #1
Flammable
Flammable's Avatar
Drives: 2012 Yaris SE
Originally Posted by tmontague View Post
I wouldn't bother checking clearances until the 180,000km range, based on the shape mine were in at 120,000km I won't be checking htem again for a while. My engine has stayed very clean under the valve cover so there is no reason for premature wear. My finacees Echo has some sludge (bought it used at 287,000km) so I'm not too sure what type of clearance I'll end up finding.
Sounds good and thanks again for the info.
Flammable is offline   Reply With Quote
Old 03-26-2015, 07:10 AM   #2
bronsin
bronsin's Avatar
I'd be suprised if the clearance is out of spec high and expect it will be slightly out of spec low. But it might be OK. Many must be.
Old 03-26-2015, 08:20 PM   #3
Flammable
Flammable's Avatar
It's funny there used to be a recommended mileage interval to check valve clearance and then Toyota did away with that recommendation all together. I have heard of people putting a ton of miles on their Yarises and never checking the valve clearances one time. I imagine there is the occational engine that will have valve issues but it appears that is rare with these motors.
Old 03-26-2015, 08:25 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
After dismantling the head I'm working on, I was surprised that the valve had no visible makes from their seats. It's like they were all new still. I think the head oly had about 60k KM though so relatively low milage but still, I thought I'd see something. I think they have a coating of some kind on them.
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 01:09 PM
Oil Pan Drain Valve guy2can DIY / Maintenance / Service 16 01-06-2018 06:06 PM
PCV valve check ; Can it be done this Hershey DIY / Maintenance / Service 7 03-31-2014 10:33 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 03:39 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 07:17 PM
