Old 03-25-2015, 10:29 AM   #17
tmontague
tmontague's Avatar
I wouldn't bother checking clearances until the 180,000km range, based on the shape mine were in at 120,000km I won't be checking htem again for a while. My engine has stayed very clean under the valve cover so there is no reason for premature wear. My finacees Echo has some sludge (bought it used at 287,000km) so I'm not too sure what type of clearance I'll end up finding.
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 12:09 PM
Oil Pan Drain Valve guy2can DIY / Maintenance / Service 16 01-06-2018 05:06 PM
PCV valve check ; Can it be done this Hershey DIY / Maintenance / Service 7 03-31-2014 09:33 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
