Old 03-21-2015, 10:01 PM   #5
Flammable
Flammable's Avatar
Drives: 2012 Yaris SE
I have great experience with shim under bucket valve clearance arrangement because its used on high performance motorcycle engine and motorcycles are my bag.
Out of maybe a dozen bikes Ive only had to adjust the valves ONCE on one engine. Ive checked clearances maybe a dozen times.
This is your chance to post if you've ever checked the Yaris clearances and what you found. Almost no one does this or at least Ive seldom seen a post.
Bonus points if you've ADJUSTED them!
Never checked mine, is there ever a need to do this?
Flammable is offline   Reply With Quote
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 12:09 PM
Oil Pan Drain Valve guy2can DIY / Maintenance / Service 16 01-06-2018 05:06 PM
PCV valve check ; Can it be done this Hershey DIY / Maintenance / Service 7 03-31-2014 09:33 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
