Old 03-21-2015, 10:01 PM   #1
Flammable
Flammable's Avatar
Drives: 2012 Yaris SE
I have great experience with shim under bucket valve clearance arrangement because its used on high performance motorcycle engine and motorcycles are my bag.
Out of maybe a dozen bikes Ive only had to adjust the valves ONCE on one engine. Ive checked clearances maybe a dozen times.
This is your chance to post if you've ever checked the Yaris clearances and what you found. Almost no one does this or at least Ive seldom seen a post.
Bonus points if you've ADJUSTED them!
Never checked mine, is there ever a need to do this?
Flammable is offline   Reply With Quote
Old 03-22-2015, 08:02 AM   #2
bronsin
bronsin's Avatar
That's what Im trying to determine. BAsed on my experience with motorcycle engine, and the fact that Ive never heard of a problem with the Yaris engine coming from not doing it, I would say no.
Its pretty easy to CHECK the clearances, but difficult to ADJUST them.
As others have said, the official requirement is 60,000 miles.
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 12:09 PM
Oil Pan Drain Valve guy2can DIY / Maintenance / Service 16 01-06-2018 05:06 PM
PCV valve check ; Can it be done this Hershey DIY / Maintenance / Service 7 03-31-2014 09:33 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
