Old 04-30-2015, 10:07 AM   #1
YodaBird
Drives: Gray
Originally Posted by vrait View Post
I'd assume he's talking about the air filter.
https://www.youtube.com/watch?v=iss_29B5V0k
Correct, the air filter. It's the same in the video as in the newer Yaris ?
YodaBird is offline   Reply With Quote
Old 05-01-2015, 08:48 AM   #2
Yes, the gen2 and the gen3 are the same. Fortunately with the gen3, thanks to the change in headlight shape, there is a bit more room to reach in and work the clips.
Old 05-01-2015, 11:31 AM   #3
YodaBird
Drives: Gray
In the video there is an electrical wiring that is disconnected, must this be done on the third generation, or no ?
Old 05-01-2015, 11:45 AM   #4
Again, the construction of the gen3 is the same as gen2. To simply replace the primary filter element, nothing needs be disconnected. He is disconnecting everything attached to the top of the air box in order to be able to flip it over and show the secondary charcoal filter to the camera.
Beware WIX Filter #51394 zkay DIY / Maintenance / Service 19 12-22-2012 12:09 AM
changing fuel filter yaris9876 DIY / Maintenance / Service 8 10-01-2011 10:03 PM
Part Number(s) for '09 5-door LB engine air filter? IsLNdbOi DIY / Maintenance / Service 5 01-02-2011 01:51 PM
Oil change without changing filter teddy DIY / Maintenance / Service 14 06-24-2009 11:50 PM
Changing engine and transmission oil poopyflux General Yaris / Vitz Discussion 4 03-09-2009 05:17 AM
