What BMW shocks did you use?
![]() ![]() Drives: 2012 Yaris 5dr Hatch Join Date: Oct 2014
I have already installed the shocks several months ago. I used monroe brand BMW e46 shocks, sourced locally were around $80 for the pair. We welded a big washer were the original piston cover sits and then slid the cover over the washer. This was done because the outer diameter of the BMW shock was slightly smaller than the yaris one so I was afraid the piston would slide through the metal hole in the original cover. This is important because this cover is also the lower base for the mounting bushings. The only other mod needed was to make the mounting holes on the rear beam larger. This was done to accommodate larger bolts as the E46 mount has a larger sleeve than the OEM. Took around 2 hours to do all of it and had made a CONSIDERABLE difference, im still looking to get it slightly stiffer. It has seen some track use too
#3 | |
Ive thought about it, however I fail to see how adding a solid bar to an already solid bar has an impact. I simply cant understand why it would make a difference given out cars suspension design.
It makes a huge difference. The beam flexes. The bar stiffens it up. Huge improvement is stability and reduced understeer. A must have!
since the yaris does not come with one from factory it makes a night and day difference , i have it on my car and its awesome ..im running the TRD and best money spend.
| need to change the rear shocks | susucosp | DIY / Maintenance / Service | 4 | 10-04-2013 06:22 PM |
| Any rear shocks out there interchangeable with Yaris? | DeathBeard | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 07-04-2013 03:58 PM |
| New "milder" Setup | Loren | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 04-26-2010 10:08 AM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
