![]() ![]() Drives: 2010 Blazing Blue 3 Door LB Join Date: Dec 2013
Best location to wire in extra 12v outlets
I plan on powering a dedicated GPS, charge 2 cell phones, 2 cell phone battery chargers(the ones that are batteries), and a heated lunchbox. I always plug the heated lunchbox into the factory 12v outlet. I plan to add 3 extra outlets to the Yaris, 2 in the passenger pocket and 1 next to the factory outlet. Where is the best place to wire in the power. I would like to have all the outlets switched so they dont stay powered after I shut the engine off and remove the key.
Thanks
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor |
Look at my remote start DIY for the ignition switched power wire on the ignition switch connector. Use that to drive the coil of a relay and feed the power to your devices via the relay's contacts from the large constant power feed on the under-dash fuse panel.
Ok, i understand the ignition switch is inside the steering column. Do I get power from any of the switched wires inside the connector clip? Green-Ignition 1 looks to be the thickest wire of the bunch or the white Accessory wire. Also what relay would you recommend, same one as used for the fog lights?
#4 | |
For the relay, a "standard" automotive relay will work just fine. The terminals labeled 85 and 86 are coil, so connect one to the ignition wire above and the other to a ground point. 30 is the common for the contacts, so connect that to the power terminal in the under dash fuse panel (make sure that you use an inline fuse between the terminal and the relay). The fuse should be sized appropriately for the size of the wire you are using and the maximum draw of the devices you will be feeding with it. 87 is the normally open contact, so that one will be the feed to your new power outlet.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY: Replacing Stock Mirrors | redyaris | DIY / Maintenance / Service | 30 | 04-20-2016 03:03 PM |
| Need extra power outlets | jambo101 | General Yaris / Vitz Discussion | 2 | 01-10-2010 04:00 PM |
| DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS | julienrl | DIY / Maintenance / Service | 1 | 08-31-2009 10:06 AM |
| Non-Yaris Audio install help needed | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 08-17-2009 11:47 AM |
