Old 11-29-2015, 07:46 PM   #1
Originally Posted by soldout View Post
Ok, i understand the ignition switch is inside the steering column. Do I get power from any of the switched wires inside the connector clip? Green-Ignition 1 looks to be the thickest wire of the bunch or the white Accessory wire. Also what relay would you recommend, same one as used for the fog lights?
You can use either the green or the pink. Remember that the ignition switch wire is only feeding the relay's coil, so there is negligible power that you are dealing with there.
For the relay, a "standard" automotive relay will work just fine. The terminals labeled 85 and 86 are coil, so connect one to the ignition wire above and the other to a ground point.
30 is the common for the contacts, so connect that to the power terminal in the under dash fuse panel (make sure that you use an inline fuse between the terminal and the relay). The fuse should be sized appropriately for the size of the wire you are using and the maximum draw of the devices you will be feeding with it.
87 is the normally open contact, so that one will be the feed to your new power outlet.
DIY: Replacing Stock Mirrors redyaris DIY / Maintenance / Service 30 04-20-2016 03:03 PM
Need extra power outlets jambo101 General Yaris / Vitz Discussion 2 01-10-2010 04:00 PM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
