Clean the throttle body and problem solved keep in mind it's by wire so key forward have someone push gas pedal to open throttle to clean do not use ur fingers to open it...this problem is common do to reset caused by no power mainly on cars with higher milage.
Sent from my Samsung Galaxy S6 |
| Tags |
| cold start, idle problem |
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Low RPM when Idle | Betrivent | DIY / Maintenance / Service | 12 | 03-03-2013 06:55 PM |
| Low rpms with a new battery | jaimico | DIY / Maintenance / Service | 8 | 04-08-2010 06:17 PM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
