#1 | ||
![]() Drives: Toyota Yaris 2014 LE Join Date: Dec 2014
Thanks once again for the prompt reply! And I'm really sorry if it seems like I'm sounding too dense, I just want to make sure everything is correct before I start the install. |
#2 | |
If the kit was aftermarket you will likely not be able to use the switch, as the aftermarket foglight kits have internal circuitry which bridges the switching and illumination circuits. The OEM switch does not do this, so you would either need to modify the aftermarket switch or use a generic switch.
#3 | |
Also I tried removed the lower switch panel with some prying toolstoday, but it just wouldn't budge. Can I just pry it open enough and than just apply controlled force to pull it off? |
#4 | |
I believe only the switch blank removes, not the whole panel. I personally have not taken apart a 3rd gen.
Cheesus, the Toyota OEM Fog light switch is $46 on Amazon
. May you send me a link to a possible generic fog light switch that could work?I meant the "pull away" part of the picture, not the panel where the switches are - the panel cover that covers all the wires behind it. |
So after looking through eBay for the Micturning Switch I posted, it states:
• Upper light is ON when the switch is pressed IN. • Lower light can be wired to separate dash light circuit. I guess it's not going to work. Will these switches be my only option? |
#7 | |
#8 | |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| 2012 Fog Light Kits | TimmyTwo2 | Third Gen Yaris General Discussion | 4 | 10-06-2014 03:41 PM |
| 2012 Fog lights FIY | Absolutely Red 12 | Third Gen Yaris General Discussion | 1 | 09-17-2012 10:31 PM |
| 2012 Yaris LB Fog Lights | TimmyTwo2 | Cosmetic Modifications (Exterior/Interior) | 6 | 03-21-2012 04:54 PM |
| Need fog light switch and relay | Jrilla | DIY / Maintenance / Service | 23 | 07-01-2011 11:12 AM |
