Old 03-30-2016, 08:27 AM   #1
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Originally Posted by beaker View Post
The flat gasket will work, you will just have to grind the flange on the muffler side flat, where originally the "half donut" gasket would fit. The should be a protrusion on the flange that holds the original style gasket in place. Or, I may be wrong in thinking the ball is on the muffler side, if it originally was on the mid pipe side, then just use the gasket. I wouldn't use silicone.
If you don't like the slip joint, just put some tack welds on it once you get everything fitted and clamped, pull it down and weld it up.
As for sliding the header on once the cross member and engine are in place, sounds like for others planning on doing this, it would be better to install the header onto the engine prior to installing the engine in the car.
Luckily the little part you are talking about was on the midpipe side originally, so the gasket should be the ticket.
I will probably just end up welding the slip joint like you said.
I would install the header before putting the engine in, or drop the crossmember.
Honestly though, I would probably just cut that tab off. I will have to cut it off with an angle grinder if I want to get the header back out. I can always fab up another mount if I need to. I am not gonna bother with a mount bracket for now.
brushforhire is offline   Reply With Quote
Old 03-30-2016, 07:58 AM   #2
LTHatch
Drives: 2013 Yaris Hatchback L
Looks awesome! Can't wait to hear how angry she will sound with your header setup, and your review on how it drives.
LTHatch is offline   Reply With Quote
Old 03-30-2016, 08:49 AM   #3
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Great results. Good to see a quick Yaris locally. Are your pans to do SCCA, strip racing, road racing, NASA, etc. with it?
MugenRep is offline   Reply With Quote
Old 03-30-2016, 12:20 PM   #4
brushforhire
I would love to do autocross, but I have no idea where to go or start with it. I might try to enter orbit with it, but I might need to add a turbo to it, before I start true space exploration.
Old 03-31-2016, 06:56 AM   #5
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
Lol, if space exploration is in question I'd start with the void im finding between some people's ears at my current job.
SCCA Central PA is pretty active. Their Facebook group seems to answer questions pretty quickly and they are one of the least condescending groups I've participated in. Not sure what class you'd be in, but according to the last time I checked I'm stuck in STS and although I'll be non-competitive it'll be great experience in learning to drive my car better. Last I looked it was $35 at most events for non-SCCA members for a Sunday fun run.
Old 03-30-2016, 05:19 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
lmgtfy =P
The NASA in question is the North American Sportscar Association. Similar to SCCA, but with different rules and classifications.
The best way to get into autocross is to find a local event, register, show up, and enjoy the day.
Old 03-30-2016, 11:11 PM   #7
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
scca.com > find my region ��
ArmstrongRacing is offline   Reply With Quote
Old 03-31-2016, 12:42 PM   #8
brushforhire
I finally found this group: Allegheny Highlands Region SCCA
They hold their events like 40 minutes from my house, and their club meetings like only 5 minutes from my house. Woo!
Old 03-31-2016, 04:04 PM   #9
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
Very very nice!!!
Old 03-31-2016, 03:11 PM   #10
ArmstrongRacing
Data doesn't lie
Nice! We're going to have a 2zr swap on each coast! 3 so far guys!
Old 03-31-2016, 07:09 PM   #11
CrankyOldMan
Does MI count as the north coast? =P
(My bonus shows up on Monday. SOOO EXCITED!)
Old 03-31-2016, 08:44 PM   #12
brushforhire
Awesome! At the rate I am getting to work on my car, you'll have yours done before mine. LoL.
Old 03-31-2016, 10:12 PM   #13
ArmstrongRacing
Data doesn't lie
YES! muahahaha!
Auto or Manual?
Old 03-31-2016, 10:52 PM   #14
CrankyOldMan
Nah, I'll be in Mexico for a week, home for a week, then in China for a week. No idea where I'll be in May.
YES! muahahaha!
Auto or Manual?
Manual. I've only got the wire harness so far, but intend to order the exhaust and ECU ASAP, and buy the motor as soon as I get back from MX.
On a side note, can you measure the ID of the MAF section? I grabbed the top of a 1ZZ Matrix/Vibe airbox at the junk yard, but I don't know if it's the right ID for the xD MAF sensor. I plan on using a CAI anyway, but need to know the right diameter to prevent a bunch of CEL issues.
Old 04-01-2016, 07:37 PM   #15
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Cranky, you should try to fit the 2ZR into the MR2.
This way you get a (simmilar) 3rd gen. powertrain in a 1st gen. shell.
Old 04-01-2016, 10:42 AM   #16
brushforhire
As a side note, I was able to reuse my old a/c lines, so I did not have to order any new ones. Thankfully. I know Armstrongracing had to use new ones, so if you have a sedan it might be different.
I got my starter and alternator wires upgraded. Did a bigger ground for the front because my battery is not located behind the passenger seat. I went with 1/0 oversized. It's obscenely huge, lol. I also used the 1/0 wire for the ground from the battery to the body.
I have to figure out where to run my 1/0 power wire from the battery to the engine bay now. I was gonna run it through the grommet where the 4 ga was, but there is not way 1/0 oversized wire is fitting through that grommet on the drivers side! Probably just drill a hole in the firewall and hide the power wire a little better.
Old 04-01-2016, 04:36 PM   #17
CrankyOldMan
Mine's a 3DR hatch. Did you have to get the xD alternator and A/C compressor?
There's another grommet behind the passenger airbag. It's easiest to see it from the engine bay, but it's under the wiper cowl. Probably a 5/8" diameter hole.
Old 04-01-2016, 04:52 PM   #18
brushforhire
I did get the alt and compressor. The xD pulleys have more ribs.
I will check for that grommet, thanks!
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
60/40 to Bench Seat Swap Issue CTScott Cosmetic Modifications (Exterior/Interior) 24 11-26-2012 02:45 PM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
