where are you guys finding the rpm package listed? I'm struggling to find the proper set up on line anywhere
#2 | |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
The only make it for the 2zrfe, if you were searching for the 1nzfe, that might be why you are having trouble finding it. I got the axles popped out, but left them in the knuckles because the axle nuts were so rusted up. I have the struts off, so at least they have a bit of wiggle room. So all I gotta do is unhook the fuel rail connector, and undo the three mounts and I should be good to take the engine out. I am planning to lift it by the outer two mounts. I removed the lower tie bar also for more room. I am thinking I just might fab up a midpipe myself. I am so torn, I was kicking around getting the OBX catless system and welding in a new flange and cat, but it is stainless, and I don't know how tricky stainless to mild steel would be to weld. |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| 60/40 to Bench Seat Swap Issue | CTScott | Cosmetic Modifications (Exterior/Interior) | 24 | 11-26-2012 02:45 PM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
