Old 04-16-2016, 01:17 AM   #1
froger
Drives: 08 yaris 1.8 dual vvti 5sp
When I did the swap,I used a 09 corolla fly wheel and clutch assembly ,I originally wanted a celica gts 2zz flywheel and clutch assembly but ran out of money,settled for used low km corolla assembly, the splines on the input shaft on the yaris transmission are the same. But no I think the bolt pattern for the clutch is different on the yaris so it won't bolt up to xd fly wheel. PS if you have a factory immobiliser , you can't just use a non immobiliser ECU,won't start ,there is something in the body wiring harness.
froger is offline   Reply With Quote
Old 04-16-2016, 06:59 AM   #2
Originally Posted by froger View Post
When I did the swap
When did you swap?
Old 04-16-2016, 10:33 AM   #3
froger
About 2 years ago ,I think ,haven't really been on the forum lately until now.
Old 04-16-2016, 11:58 AM   #4
So you beat ArmstrongRacing to the swap which got exposure as the first US 2ZR-FE powered Yaris http://www.subcompactculture.com/201....html?m=1#more
Canada TRUMPS the United States (see what I did there)
Old 04-16-2016, 08:56 PM   #5
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
lets see some pictures!!!
Old 04-17-2016, 12:03 AM   #6
froger
All xd in Canada used a second generation immobiliser system so all the keys have a small G in graved on the key,my yaris had a first generation so it has a dot in graved on the key,couldn't get the old generation immobiliser to work with the xd ecu ,so just ended up getting a xd immobiliser ,xd computer and xd keys(chip is different). As for the shift cables yes xd cables are the only ones that work properly. It turns out the dimensions of the subframe are similar from what i figured,only difference is the xd subframe looks more reinforced,both cars even have same wheel base,so I also ended up using the xd sway bar as well ,it's thicker by a couple of mm.the distance of the sway bar is the same,both use same control arms ,knuckles and struts.so it possible to do a five bolt hub conversion as well ,only if you wanted to.
Old 04-17-2016, 12:38 AM   #7
froger
The pictures are crap ,taken with crappy cell phone camera,also I don't have an Xd air box ,using a corolla air box for now.
Old 04-18-2016, 01:12 PM   #8
Jeff Lange
Drives: 11 GSE21, 86 AE86
Yeah, I think yours was finished around the end of July, 2014.
In Canada most all Toyota's after 2007 came equipped with a immobiliser
All vehicles build after 08/2007 in Canada are required to have an immobilizer, this includes Yaris and xD models. We didn't have xD until 2011, however ours did have immobilizer.
I though initially it was just a matter of buying a American xd ECU with out a immobiliser but failed.(car no start)
After some research found that on immobiliser and non immobiliser engine wiring harness are the same but the body wiring harness is different,figure there is something in the harness that tells the engine ECU that there is a immobiliser ecu.
Yes, the engine harness and engine ECU are the same for vehicles with and without immobilizer. All of the changes are on the body harness side. On froger's car he tried to remove the immobilizer wires heading into the ECU and disconnecting the immobilizer on the body side. According to all of the published wiring diagrams, everything was as it would be on a Yaris without immobilizer, however the ECU (from a non-immobilizer car), still threw a code for immobilizer.
didn't want to deal with dissecting harness so ended up changing engine ECU ,immobiliser ECU and keys( had to change second gen g keys).
Ended up using a 2011-12 xD 2ZR-FE engine ECU, 2011-2014 xD/Yaris Sedan immobilizer ECU with the newer 3rd-gen immobilizer keys ('G' mark - 89785-08040) to match the vehicle. May have been able to keep using the original immobilizer system if done properly, however I cannot recall what the issue with that was off the top of my head. I think froger just wanted to be sure and so he made everything match.
NOTE: if you doing the swap don't use yaris shift cables,there too short(they will work),The new mounts push the tranmission forward by 2 inches ,ended up ripping out the studs off the body which hold the cables,two holes in body had to weld the studs back in.
Yeah, the ZSP90 Yaris (factory 2ZR-equipped Yaris) used the same shift cables as the xD, so the xD cables were the proper ones to use. The NCP Yaris cables are shorter for sure.
Jeff
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
2005 Toyota Yaris RS 5MT Short Track Car
Jeff Lange is offline   Reply With Quote
Old 04-20-2016, 11:21 AM   #9
ArmstrongRacing
Data doesn't lie
Jeff
This is not applicable to those just swapping in the 2zr and keeping the Yaris C50. If you use the Yaris trans and mounts, the stock shift cables are fine.
Old 04-20-2016, 04:52 PM   #10
Jeff Lange
It is applicable if using the 2ZR mounts, even if keeping the Yaris C50. Obviously if you keep using the 1NZ mounts the transmission will still be in the correct location to keep using the original cables.
Jeff
Old 04-24-2016, 11:28 AM   #11
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Good to know!
Correct. There's a K-line communications wire that goes to the immobilizer ECU that needs to be disconnected.
My 2zrfe swap brushforhire Performance Modifications 131 06-08-2016 09:43 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
