dindy
Drives: toyota vitz Join Date: Apr 2016
normal temp?
is 95celsuis of coolant on vitz mk2 is normal? I notice that the fan starts operating at 95celcuis, via tachyon obd scanner.
That sounds a tad high. 183F (84 C) is where my MK2s typically sit, but the service manual says that up to 212F (100C) is normal.
In my Yaris, it typically runs between 188 and 195F (summer) and in stop and go traffic it will go as high as 212F (summer) but the fan doesn't kick in until 208F. In my Echo the fan kicks on at 210-212F.
It seems high compared to some older cars, but for a newer age cars and small engines it seems pretty normal.
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
mine runs between 86~95 :)
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() Drives: '15 Dodge Challenger Join Date: Aug 2011
Living in Canada, I only ever have my fan kick on during the couple months in the summer when I am using the AC, most of the year my car gets up to about 80C at most
#6 | |
Even at 22 C temps in city traffic when stopped the fan will usually run for very brief periods. Mind you, that's in my Echo which has about 1/3 of the rad fins gone so that could also be why
Yeah, mostly 10 mins into town, 10 mins home, but i do ~30min highway trips to work and back but all the air rushing in keeps it below the point where the fan will normally kick in. Also running a higher pressure in the cooling system so that might have some effect as well
| Normal or not normal? | Septembersrain | Third Gen Yaris General Discussion | 7 | 05-27-2013 12:50 PM |
| Smoke smell question. Is this normal? | Ilovemyyaris | DIY / Maintenance / Service | 6 | 08-10-2012 02:04 PM |
| Turbo Charged Normal Engine Temp. | Over40 | Forced Induction Forum | 9 | 03-01-2009 01:27 AM |
| outside temp on cluster??? | ae92trueno7 | Cosmetic Modifications (Exterior/Interior) | 11 | 01-01-2009 10:36 PM |
