Old 04-19-2016, 03:25 PM   #1
whitenergy1986
dindy
Drives: toyota vitz
normal temp?
is 95celsuis of coolant on vitz mk2 is normal? I notice that the fan starts operating at 95celcuis, via tachyon obd scanner.
whitenergy1986 is offline   Reply With Quote
Old 04-19-2016, 07:48 PM   #2
That sounds a tad high. 183F (84 C) is where my MK2s typically sit, but the service manual says that up to 212F (100C) is normal.
Old 04-19-2016, 07:57 PM   #3
tmontague
tmontague's Avatar
In my Yaris, it typically runs between 188 and 195F (summer) and in stop and go traffic it will go as high as 212F (summer) but the fan doesn't kick in until 208F. In my Echo the fan kicks on at 210-212F.
It seems high compared to some older cars, but for a newer age cars and small engines it seems pretty normal.
Old 04-22-2016, 12:28 AM   #4
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
mine runs between 86~95 :)
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 04-23-2016, 03:05 PM   #5
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
Living in Canada, I only ever have my fan kick on during the couple months in the summer when I am using the AC, most of the year my car gets up to about 80C at most
z0mb13k1ll is offline   Reply With Quote
Old 04-23-2016, 03:49 PM   #6
tmontague
tmontague's Avatar
You do a lo of short trips?
Even at 22 C temps in city traffic when stopped the fan will usually run for very brief periods. Mind you, that's in my Echo which has about 1/3 of the rad fins gone so that could also be why
Old 04-23-2016, 03:51 PM   #7
z0mb13k1ll
z0mb13k1ll's Avatar
Yeah, mostly 10 mins into town, 10 mins home, but i do ~30min highway trips to work and back but all the air rushing in keeps it below the point where the fan will normally kick in. Also running a higher pressure in the cooling system so that might have some effect as well
Normal or not normal? Septembersrain Third Gen Yaris General Discussion 7 05-27-2013 12:50 PM
Smoke smell question. Is this normal? Ilovemyyaris DIY / Maintenance / Service 6 08-10-2012 02:04 PM
Turbo Charged Normal Engine Temp. Over40 Forced Induction Forum 9 03-01-2009 01:27 AM
outside temp on cluster??? ae92trueno7 Cosmetic Modifications (Exterior/Interior) 11 01-01-2009 10:36 PM
