Old 05-10-2016, 08:12 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
sway bar do make difference, so does front tower strut...higher octane do make a difference...after i upgraded to E85 with larger injectors and ecu, i gained good 10whp+
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 05-10-2016, 08:09 PM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Going to just a higher octane and nothing else, will not give more power, on a stock yaris. Now if other things are changed and modified, that's a different story.
The only reason why a higher octane would give more power, is if the car was compensating for detonation, running rich. Since our cars are designed to run on lower octane, nothing happens by using a higher octane.
brushforhire is offline   Reply With Quote
Old 05-10-2016, 09:50 PM   #3
rabbito
rabbito's Avatar
yes, running higher octane does not do anything but running higher octane, larger injector and advance timing or controling fuel does make a difference
Old 05-11-2016, 06:33 AM   #4
brushforhire
Fair enough. LoL
Old 05-11-2016, 08:46 PM   #5
Jason@SportsCar
A front strut tower brace will offer no improvement on a Yaris if you are still using the stock upper strut mounts. You have a strut that is mounted in an inch thick rubber doughnut, that is not even positively affixed to chassis, the damn thing just floats in there.
Replace the top mount with a proper bearing plate first, otherwise you are just burning money.
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 08:04 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
