Old 05-10-2016, 08:12 AM   #16
rabbito
rabbito's Avatar
sway bar do make difference, so does front tower strut...higher octane do make a difference...after i upgraded to E85 with larger injectors and ecu, i gained good 10whp+
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 08:04 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
