#18 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
| budget B Spec rally build slowly coming along | 07dirtyaris | Tracking, Racing, Auto-X Forum | 8 | 08-15-2016 04:21 PM |
| 1NZ-FE All Motor Build | burned | Performance Modifications | 19 | 10-24-2014 10:56 AM |
| Turbo build - stage 1:D | abstractmethod | Forced Induction Forum | 21 | 03-13-2014 08:04 AM |
| Carbon build up in the throttle body | Sedan | DIY / Maintenance / Service | 18 | 11-15-2013 11:44 PM |
