Old 05-09-2016, 08:07 PM   #11
CoryM
Drives: 2009 5-door, 5-speed
Late reply as I was moving house and having surgery.
Thanks for the input guys.
Looking at the 2016 rules, it looks like this truly was a useless post . I use the Yaris in a winter series, so up until now I was still on 2015 rules. Looks like this winter I'll just be racing for fun as I'm not doing a STF build. I run on NT01s because I get them cheap to the point I'd be stupid to run anything else. The raw grip, and resistance to heat cycling makes them a pretty good street/autoX tire IMO. Enough to forgive the low responsiveness.
Regarding the front bar at autoX, have you guys tried this exact setup? The front bar was the last change I did (after 5yrs), and definitely seems faster. I am familiar with suspension design (I have designed/built a car from scratch), and I understand that the front bar is "wrong" for a FWD. However I saw pictures of my car with only 1-2" of rubber on the drive wheel contacting when on power in corners: I figured I would try a front bar to reduce the savage body-roll. From photos it appears to have nearly doubled the amount of rubber on the road, without causing the understeer to be unmanageable. It is absolutely faster in many elements with the front bar. Slaloms, offset gates, keyhole turns. Also allows me to brake later/harder without losing the rear. Basically anything except corners on launch, and bumpy sweepers. The only place (which never happens at autoX) that the front bar shows massive understeer is trying to turn hard without transferring the weight to the front (turning without braking or lift-off). That being said, it's certainly possible that I have gone too far, and that the 2015 bar may be a better option. For my driving, I'd say the current setup is pretty solid.
On the track, or with stiffer springs, I doubt you'd want the front bar. You really need that aggressive weight transfer like you get at autoX. I'm not a track guy, so I can't say for sure, but I bet it would be worse.
Cheers.
Cory
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 08:04 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
