Put the meter in resistance mode and check for continuity (<2 ohms) between each wire and the lug on the alternator. The one to the alternator goes to the rear terminal.
![]() Drives: Yaris 07, Delorean 82 Join Date: Aug 2015
OK, Thanks. Once I started putting everything back in everything fell into place very easily. End result pictured. Thanks for everyone's help.
| Tags |
| fusible link, positive battery terminal |
| Fusible link and Terminal End Removal | smb24601 | DIY / Maintenance / Service | 8 | 08-11-2016 03:16 PM |
| Wiring Diagram for under bonnet (hood?) fusebox | azeeroth | DIY / Maintenance / Service | 5 | 11-11-2013 08:22 PM |
| MK1 Yaris SR - Wiring diagram. | YarisSR | General Yaris / Vitz Discussion | 2 | 08-03-2011 03:44 PM |
| Wiring diagram? | fwynn | DIY / Maintenance / Service | 4 | 05-05-2010 09:00 PM |
| NEED TPMS Wiring Diagram please | mikenacarato | DIY / Maintenance / Service | 9 | 02-11-2009 11:55 PM |
