Old 05-05-2010, 01:29 AM   #1
fwynn
Drives: 1999 NHBP Honda Prelude
Wiring diagram?
Hey guys I did a search and I couldn't find it.. I'm trying to find a wiring diagram for the 09 Yaris Sedan. I'm trying to install an alarm system with the Remote start. I bought my girl a Viper 5901 system and would like to install it! :] I'm new in electrical kinda.. but i do know the basics as well as some details....
We took the car to a shop named Promax located in Alhambra, Ca.. and they COMPLETELY failed on the install... when they installed it... when the unlock button is pressed it beeps 3 times instead of 2 times.. when you drive the LED on the transponder box thing keeps beeping...(It's supposed to not flash when you're driving)... When the lock button is pressed it beeps once.. like it's supposed to.. HOWEVER it says there is a door open.. ALSO there are no lights that flash when the buttons are pressed..
They said it can be a defective box.. however once they told me "you're LED's may be interfering with the brain.. It may be draining too much power" (the LED's are in the dome light and map light. replaced them because the stock lights were not bright enough.. besides LED's take out less power than regular bulbs) I have the Clifford 50.7x on my car (Honda prelude) and i have LED's everywhere.. and it works perfectly.. so the LED part fails..
So I really need your help guys.. I saw the Remote start diagram thing :] but i also need the alarm part :]. Thanks!
fwynn is offline   Reply With Quote
ECU Wiring Diagram? thebarber DIY / Maintenance / Service 16 05-22-2025 08:07 PM
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 11:06 AM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 12:43 PM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 04:56 PM
NEED TPMS Wiring Diagram please mikenacarato DIY / Maintenance / Service 9 02-12-2009 12:55 AM
