Old 08-11-2016, 05:26 PM   #4
smb24601
Drives: Yaris 07, Delorean 82
So how can I determine which one is the alternator even with a multimeter. Both the ones with the plastic connectors are still intact, I was able to get those out easy.
Originally Posted by brushforhire View Post
One goes to the starter, the other goes to the alt. I would get a test light and probe each end and see which is which. I will have to do some digging to see what mine was. I know I just used a multi-fuse block when I did my battery relocation.
Edit: After looking at some diagrams, I believe the Alternator cable gets the fuse, and the starter cable goes straight to the 12v+ terminal. I know the littler white wire also got fused.
smb24601 is offline   Reply With Quote
fusible link, positive battery terminal
Fusible link and Terminal End Removal smb24601 DIY / Maintenance / Service 8 08-11-2016 03:16 PM
Wiring Diagram for under bonnet (hood?) fusebox azeeroth DIY / Maintenance / Service 5 11-11-2013 08:22 PM
MK1 Yaris SR - Wiring diagram. YarisSR General Yaris / Vitz Discussion 2 08-03-2011 03:44 PM
Wiring diagram? fwynn DIY / Maintenance / Service 4 05-05-2010 09:00 PM
NEED TPMS Wiring Diagram please mikenacarato DIY / Maintenance / Service 9 02-11-2009 11:55 PM
