Old 08-11-2016, 04:53 PM   #3
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
One goes to the starter, the other goes to the alt. I would get a test light and probe each end and see which is which. I will have to do some digging to see what mine was. I know I just used a multi-fuse block when I did my battery relocation.
Edit: After looking at some diagrams, I believe the Alternator cable gets the fuse, and the starter cable goes straight to the 12v+ terminal. I know the littler white wire also got fused.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
Tags
fusible link, positive battery terminal
Fusible link and Terminal End Removal smb24601 DIY / Maintenance / Service 8 08-11-2016 03:16 PM
Wiring Diagram for under bonnet (hood?) fusebox azeeroth DIY / Maintenance / Service 5 11-11-2013 08:22 PM
MK1 Yaris SR - Wiring diagram. YarisSR General Yaris / Vitz Discussion 2 08-03-2011 03:44 PM
Wiring diagram? fwynn DIY / Maintenance / Service 4 05-05-2010 09:00 PM
NEED TPMS Wiring Diagram please mikenacarato DIY / Maintenance / Service 9 02-11-2009 11:55 PM
