![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
I change mine every 2 years...
^this
![]() Drives: e61 Join Date: Oct 2016
#4 | |
I say an opened but resealed container of brake fluid will NOT absorb moisture even after three years! In a car brake fluid is NOT sealed but its debateable how much water it will absorb. A FoMoCo study found less than 1% water after seven years in its cars.
#5 | |
#6 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Simply put, $5-10 worth of brake fluid every 2yrs to reduce the chances of calipers seizing is a no-brainer. |
#7 | |
it will not cause any damage, i separated the brake fluid from the car, just to check, anyway it is very cheap
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| Brake Fluid reservoir hose, is it suppose to be like this ? | Goldenyaris | DIY / Maintenance / Service | 0 | 12-15-2014 07:31 AM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| Will this hold? Plastic bag vs brake fluid | lamadoo | DIY / Maintenance / Service | 7 | 04-25-2013 03:35 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
