Old 11-02-2016, 11:24 AM   #7
CoryM
Drives: 2009 5-door, 5-speed
Originally Posted by bluethree View Post
i recently bought a brake fluid tester to test if the fluid is water-contained As the standard if the brake fluid should be changed
Use a bit of caution with those: They are often very inaccurate. And you will also want to sample from different areas of the system which is pretty hard to do.
Simply put, $5-10 worth of brake fluid every 2yrs to reduce the chances of calipers seizing is a no-brainer.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Brake Fluid reservoir hose, is it suppose to be like this ? Goldenyaris DIY / Maintenance / Service 0 12-15-2014 07:31 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
