Old 11-01-2016, 02:49 PM   #1
sorka
Drives: 2007 Yaris Sedan
Originally Posted by CrankyOldMan View Post
I was going to say not to reuse them, but the manual doesn't specify them as non-reusable. Very strange if they are in fact stretct/torque-to-yeild but can be reused. I guess for the small cost of a new set, it's worth my peace of mind to not have to worry about one shearing off and destroying the clutch.
My local Toyota dealer says they can get them by tomorrow morning at 8:30 AM. Was going to start putting it all back together tonight but will hold out if they actually get the bolts. Cost $2.71 each which actually isn't a total ripoff as that was more than a $1 cheaper than the dealer near my work. Not that I wouldn't have paid the $4 but it's nice to see a local dealer not trying to ream me. The online price range from $1.97 on up.
sorka is offline   Reply With Quote
Old 11-02-2016, 09:11 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by sorka View Post
Cost $2.71 each...
Just a quick cost vs risk assessment.
New bolts:
$16.26 + tax
Waiting one day to get them.
Grenaded clutch/flywheel repair (cheapest aftermarket I found in 10 second search):
$63 Replacement brand clutch kit
$50 Luk brand flywheel/flex plate
$16.26 for a new set of bolts (old ones will probably not be salvageable)
Hours/days downtime tearing out engine/trans to replace
Even if you skip the OEM clutch and flywheel and go super low quality, you're out at least a weekend to pull everything apart. Investing the $20 while you've already got it apart seems to be a no-brainer to me.
That said, I agree that elastic deformation bolts can be re-used, plastic deformation cannot. But without a length spec in the manual to verify against, or a good understanding of what a plastic deformed bolt looks like, it's a crap shoot.
Old 11-02-2016, 11:32 AM   #3
CoryM
Drives: 2009 5-door, 5-speed
New bolts:
$16.26 + tax
A flywheel has a huge amount of inertia. If the bolts were to suddenly shear at 6500rpm you would need a new car.
https://www.youtube.com/watch?v=n0TxZFDLa3w
This is why it is not something to play around with.
Cheers.
Old 11-02-2016, 01:18 PM   #4
CrankyOldMan
I was thinking more of a single head shearing off and tumbling around inside, but yes, a total failure at redline would be catastrophic for everything around it. That's why real racecars are required to have a shroud around the flywheel that protects the driver and bystanders.
Questions for new flywheel and clutch mrbond Performance Modifications 11 07-11-2013 07:17 AM
Flywheel question-1nz conversion-2003 Model Echo56 DIY / Maintenance / Service 0 05-21-2013 10:42 PM
