2ZR swap. DO IT! Ask how!
Just a quick cost vs risk assessment.
New bolts: $16.26 + tax Waiting one day to get them. Grenaded clutch/flywheel repair (cheapest aftermarket I found in 10 second search): $63 Replacement brand clutch kit $50 Luk brand flywheel/flex plate $16.26 for a new set of bolts (old ones will probably not be salvageable) Hours/days downtime tearing out engine/trans to replace Even if you skip the OEM clutch and flywheel and go super low quality, you're out at least a weekend to pull everything apart. Investing the $20 while you've already got it apart seems to be a no-brainer to me. That said, I agree that elastic deformation bolts can be re-used, plastic deformation cannot. But without a length spec in the manual to verify against, or a good understanding of what a plastic deformed bolt looks like, it's a crap shoot. |
#2 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
https://www.youtube.com/watch?v=n0TxZFDLa3w This is why it is not something to play around with. Cheers. |
I was thinking more of a single head shearing off and tumbling around inside, but yes, a total failure at redline would be catastrophic for everything around it. That's why real racecars are required to have a shroud around the flywheel that protects the driver and bystanders.
| Questions for new flywheel and clutch | mrbond | Performance Modifications | 11 | 07-11-2013 07:17 AM |
| Flywheel question-1nz conversion-2003 Model | Echo56 | DIY / Maintenance / Service | 0 | 05-21-2013 10:42 PM |
