Old 11-02-2016, 11:52 PM   #1
bluethree
Drives: e61
Originally Posted by CoryM View Post
Use a bit of caution with those: They are often very inaccurate. And you will also want to sample from different areas of the system which is pretty hard to do.
Simply put, $5-10 worth of brake fluid every 2yrs to reduce the chances of calipers seizing is a no-brainer.
yes,u are right. i want to check the savety of the fluid. you know,poor quality of the brake fluid may cause traffic accidents, although this is rarely happened...
it will not cause any damage, i separated the brake fluid from the car, just to check, anyway it is very cheap
bluethree is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Brake Fluid reservoir hose, is it suppose to be like this ? Goldenyaris DIY / Maintenance / Service 0 12-15-2014 07:31 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
