Old 11-27-2016, 04:21 PM   #1
Pinchlite
Drives: 2007 yaris HB
springs
Well those are 1.5 and are almost double the cost of what I linked.$358.00 CAD.
Would 1.5 even make a visually noticable difference?
If the ones I linked are no good then I will probaly hold off putting the new rims on this summer.
Pinchlite is offline   Reply With Quote
Old 11-27-2016, 04:35 PM   #2
SirDigby
Drives: 2007 yaris 3 door
you get what you pay for. Tein's are almost the best suspension components you can get for under $4000.
1.5 makes a huge difference in visual appearance.
Old 11-27-2016, 04:37 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
One can find teins at a lower price and ya it's a noticeable difference between 1.5 and 2 inch drop.
Sent from my HTC One A9 using Tapatalk
Old 11-27-2016, 06:00 PM   #4
Pinchlite
1.5
So 1.5 drop with the wheels and tire sizes I posted/mentioned would look okay.(2 DR HB)
As long as it does not have too much gap then I may go 1.5 and go for the tein spring afterall.If a few things go as planned I can swing it in my budget.
Old 11-27-2016, 06:02 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Well I would go with drop first than wheels with ur wheels I think teins should be fine.
Go low or go home lol
Old 11-27-2016, 06:07 PM   #6
Pinchlite
springs
Thats my plan.I will not be putting on new wheels untill I lower.
I just was not sure 1.5 was enough as I have read many posts that say 1.5 is not even noticable?
Did you see the wheel and tirespecs I posted?
Old 11-27-2016, 06:08 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Well I'm on 195 55 15s and on teins so compare that size to urs and I'm 42 offset.
Old 11-27-2016, 06:13 PM   #8
Pinchlite
lowering
I already have this bought.
205/45R16 Comp 2
Wheels:16x7/4x100mm offset 40
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
