![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
springs
Well those are 1.5 and are almost double the cost of what I linked.$358.00 CAD.
Would 1.5 even make a visually noticable difference? If the ones I linked are no good then I will probaly hold off putting the new rims on this summer. |
#2 | |
1.5 makes a huge difference in visual appearance. |
#3 | |
Sent from my HTC One A9 using Tapatalk |
1.5
So 1.5 drop with the wheels and tire sizes I posted/mentioned would look okay.(2 DR HB)
As long as it does not have too much gap then I may go 1.5 and go for the tein spring afterall.If a few things go as planned I can swing it in my budget. |
#5 | |
Go low or go home lol Sent from my HTC One A9 using Tapatalk |
springs
Thats my plan.I will not be putting on new wheels untill I lower.
I just was not sure 1.5 was enough as I have read many posts that say 1.5 is not even noticable? Did you see the wheel and tirespecs I posted? |
#7 | |
lowering
I already have this bought.
205/45R16 Comp 2 Wheels:16x7/4x100mm offset 40 |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 03:18 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-10-2009 10:12 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 06:49 PM |
