Old 11-27-2016, 07:24 AM   #5
Pinchlite
Drives: 2007 yaris HB
lowering
Well I already have rims and tires in the dimensions that I mentioned earlier.
I can only afford springs.
Basic question would this work without being a problem?
1 3/4'' drop
P.S
I may be able to squeeze in the sway bar into my budget if it helps?
Pinchlite is offline   Reply With Quote
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
