Old 04-24-2007, 04:59 PM   #1
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
I don't have this problem, however, I have another problem with the brake. When I'm stopped, and applied the hand brake, I have to pull the handle pretty high in order to get the car to steady, or else it will be making squaking sound when I step out of the car or moving inside the car. Is this because of the Drum brake? As this is the first car I have drum brake on. Thanks.
GabL is offline   Reply With Quote
Old 04-24-2007, 08:27 PM   #2
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
yeah you need to adjust your e-brake
http://www.etimago.com/yaris/repairm...ng%20Brake.pdf
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
