Old 02-11-2017, 11:53 AM   #1
SirDigby
Drives: 2007 yaris 3 door
I took a piece of 90 degree copper tubing and plugged the coolant lines together around the corner of the head by-passing the throttle body. you would need to replace the hoses, at least 1, with aftermarket tubing. if you want to use stock air box /w accordion rubber duct, I've read that you can turn the tube around 180 degrees and it fits on 1zz. I have not tested. I have a injen CAI.
Old 02-11-2017, 11:58 AM   #2
rabbito
rabbito's Avatar
dude...that was so helpful..thank you ✊✊✊✊
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Old 02-12-2017, 12:28 PM   #3
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
I think you can do without the coolant lines on the TB in Thailand. :wink
You can probably leave them in loop.
Cooland flows there to prevent icing and sticking of the throtle plate with frozen condensation vapors.. not a case in your part of the world I think :)
ncp13 is offline   Reply With Quote
1zz Throttle Body Question rabbito Performance Modifications 5 12-08-2015 11:09 PM
1zz or 2zz throttle body swap BoostedTRD Performance Modifications 1 11-25-2014 10:05 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
