![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
1zz TB question
i failed to install the 1zz throttle body due to...
1. fu*ken coolant hose being too short and couldnt reach the throttle body..😣 2. i wanted to use stock intake box with plastic hose but couldnt fit over 60mm..lol.. 😥 is anybody using stock airbox for 1zz 60mm tb? i custom ordered stainless steel intake 2.5" from a shop to try to make it possible...(picture below..sorry for sucky drawing..) 😆 if not..how is your car running on normal intake + 1zz throttle body?? im trying to use stock box because i hate losing low end torque..i had hks intake which lost low end and gained hi end 20170209_151904.jpgScreenshot_20170211-211627.png Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
I took a piece of 90 degree copper tubing and plugged the coolant lines together around the corner of the head by-passing the throttle body. you would need to replace the hoses, at least 1, with aftermarket tubing. if you want to use stock air box /w accordion rubber duct, I've read that you can turn the tube around 180 degrees and it fits on 1zz. I have not tested. I have a injen CAI.
#3 | |
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
I think you can do without the coolant lines on the TB in Thailand. :wink
You can probably leave them in loop. Cooland flows there to prevent icing and sticking of the throtle plate with frozen condensation vapors.. not a case in your part of the world I think :) |
Yes, you can definitely by pass the coolant. I just bought generic coolant hose and cut it to fit for the 1zz TB. I didn't want to bypass the coolant as I live in a cold climate.
I had a TRD intake that came with a silicone coupling. It was too small to fit over the 1zz but i was able to stretch it to fit and clamp it downs with a zip tie. The stock hose is stiffer and not as easily stretched.
feed my pet
Hi rabbito, I think 1ZZ TB is 55mm unless your using Thai TB which I saw is 60mm. You could just purchase a longer coolant hose with custom length.
I'm using 1ZZ TB with stock air intake. Tooter mentioned that I could use the stock hose by just switching the ends but it is a very tight fit for 55mm. Might need to stretch/force it a little for TB side. |
| 1zz Throttle Body Question | rabbito | Performance Modifications | 5 | 12-08-2015 11:09 PM |
| 1zz or 2zz throttle body swap | BoostedTRD | Performance Modifications | 1 | 11-25-2014 10:05 AM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
