Old 02-23-2017, 08:21 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by kevinj93 View Post
I would avoid putting the rear speakers in parallel with the front speakers. The head unit is designed to drive a 4 ohm load. If you put the 2 sets of speakers in parallel, you will be asking it to drive a 2 ohm load. There is a real possibility you will overload the output stage and burn it out.
If your head unit does not have separate outputs for the rear speakers, you would need to replace it or add an amplifier to drive the rear speakers.
The power rating on the speakers is not what they require, but the maximum they are rated to handle. you don't 'need' that much power. try them "as is", and you can add an amplifier or change head units if you feel they aren't loud enough.
Actually, the fujitsuten head unit is 2ohm stable. It was designed to drive tweeters in parallel with the full range door speakers. Not necessarily on the yaris, but also on other models. The Pioneer is probably 2ohm capable too, but I'm not sure about this.
Either way, the rear speakers should split from either side of the front kick panel. I forgot which side, so all you have to do is tap there and run the wires to the back and you get rear speakers working.
Sent from my SM-G930W8 using Tapatalk
Old 02-23-2017, 08:24 PM   #2
miiser
miiser's Avatar
Drives: yaris 2009
I didn't quite catch up what you said exactly. You mean there are ready wirings inputs??
miiser is offline   Reply With Quote
Old 02-26-2017, 09:43 PM   #3
IllusionX
Yes. I dont see why wires would be removed at the HU harness. I am pretty sure the audio wires come out of either side of the kick panel. Look up the kick panel connector wiring manual..
Old 02-27-2017, 07:57 PM   #4
miiser
miiser's Avatar
Drives: yaris 2009
In line rear speakers wiring? Possible?
Do you know where to search for them?
I am not really into these things so if you could navigate me on the area I need to look for it would be really helpful
FS: polk audio 5" rear speakers brand new knobby bobby Items for Sale by private party 2 11-04-2014 03:48 AM
Installing rear speakers in a 3dr HB (2008) watersoilair DIY / Maintenance / Service 1 04-04-2012 07:26 AM
One of my rear speakers sound like its pluged up?!? YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 10-01-2009 12:49 AM
