Old 05-02-2017, 10:30 AM   #1
Doesn't matter what the OE actual wheel sizing is, the space savers are always smaller. 14" is what you want.
Old 05-02-2017, 03:25 PM   #2
funky2nite
Drives: 2013 Hybrid 1.5L T4
Thanka mate, how very much appreciated. And what a fabulous place to come to to have a clarified opinion/advice.
Thanks every one.
funky2nite is offline   Reply With Quote
Old 05-02-2017, 03:28 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
We must be different here "down under". Our space saver spare is a 16x4 wheel with a 125/70x16 tyre. it's recommended inflation pressure is 60 PSI.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 05-02-2017, 03:32 PM   #4
funky2nite
Huh..?
Old 05-03-2017, 04:18 AM   #5
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
That's what we get as a spare. It's a "space saver" - 16x4 rim with a 125/70x16 tyre.
The base model has the 2NZ-FE and until recently had 14 inch wheels with 175/70x14 tyres, and the upmarket models have the 1NZ-FE wrih 15 inch wheels and 175/65x15 tyres. Both get the same size spare, which is marked as being speed limited to 80 km/h (50mph).
The spare is recommended to only be used on the rear, so if you get a flat front,vyou are supposed to swap a rear tyre to the front, and put the spare on the back.
Old 05-03-2017, 04:29 AM   #6
funky2nite
Then if I'm understanding you guys well, 14" can still be fitted on 15", and as you're saying, in a smart approach, said space save wheel should ideally be fitted on the rear ones only, seeing ours are FWD.
Old 05-03-2017, 04:39 AM   #7
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Yes, but....
The narrow space saver will have less grip. This could be aproblem on the driving wheels. The differnece in diameter can also affect the anti lock brakes It's basically an emergency measure to get you to the nearest tyre shop.
Changing to an MR2 Roadster Steering wheel MESSIAH DIY / Maintenance / Service 2 05-03-2015 12:02 PM
Black/Grey OEM Leather Steering wheel question heeroyuy01195 Cosmetic Modifications (Exterior/Interior) 12 10-14-2011 01:22 AM
Wheel Well Question gwasabi Cosmetic Modifications (Exterior/Interior) 3 04-15-2009 12:09 PM
Question about wheel Offset monoculusjoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-07-2006 03:03 AM
Wheel and tire question. EddyCocaine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 08-31-2006 11:13 AM
