Old 05-03-2017, 06:52 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
It's more work pressing out a ball joint for replacement than switching the actual control arm. That's why dealers don't do it.
Sent from my SM-G930W8 using Tapatalk
Old 05-03-2017, 08:55 AM   #2
tmontague
tmontague's Avatar
In a non corroded car, yes. However in a corroded car with a seized control arm bolt to the bushing it will take hrs to remove.
With a proper c type press it can be removed with the control arm still on the car of you pull the knuckle out of the way. There is very little room fornrust to build up on the ball joint and control arm mating surface so a press makes quick work.
Oddly enough when I replaced the control arms on my '02 Echo a couple years ago, they came out very easily. There was 340k km on it and it was never oil sprayed. My Vibe with 250k km was a totally different story...
aftermarket ball joint for lower applications tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 12-28-2019 04:05 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
URGENT. BALL JOINT REINSTALLATION QUESTION xb visitor DIY / Maintenance / Service 4 05-09-2014 06:02 AM
Putting on dust cover boot ring on ball joint yaris4062007 DIY / Maintenance / Service 10 04-21-2013 12:51 PM
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 06:27 PM
